  #31
Old 12-24-2013, 01:31 AM
bsch3r,
Software tools monitor voltage thru driver, which is as we all know limited to 1.212V. Often setting higher voltage renders incorrect values or just simply stucks 1.212V
Use usual DMM/voltmeter to probe header on top edge of card.
Pin 1 (one closer to GPU side, if card front faced to you) - GPU Voltage
Pin 2 - GND
Pin 3 - Memory voltage
Pin 4 - GND
Pin 5 - PLL Voltage
Pin 6 - GND
Pin 7 - +3.3V
Pin 8 - GND
Pin 9 - +12V
Pin 10 (one closest to VRM area) - GND again
You can use any GND, they share same connection.
Also on Ti's ASIC quality is not matter much, i saw 65% cards do 1350MHz on stock cooling, and 80% not being able to reach 1270MHz on same conditions
Old 01-08-2014, 03:39 AM
PhazeDelta1 PhazeDelta1 is offline
Originally Posted by FTW12345 View Post
Hi strongisland1,
is it BSOD after system reset? i ever saw that on reference ti by myside.
based on that experience i modified a bios for you.
http://www21.zippyshare.com/v/88888925/file.html
I have a question concerning that bios. Under the voltage table, Is it possible to unlock Max Voltage #2 or is Max Voltage #1 sufficient?
Old 07-28-2015, 03:53 PM
loon iam's Avatar
loon iam loon iam is offline
***update -- Classified Controller 2.1.2 version***
Update to 2.1.2 to fix memory voltage incorrect issue.
http://www70.zippyshare.com/v/hpjnrFub/file.html
my 980TIclassy says thank you!
Old 07-28-2015, 06:46 PM
Uing
My friends said that awesome!!
Old 07-28-2015, 07:29 PM
FTW12345 FTW12345 is offline
Old 07-28-2015, 10:57 PM
Lays Lays is offline
Anybody know why my 980 Classified 3988 SKU crashes under load with software voltage control?
I ran 1600/8700 in a firestrike run at stock volts (1.23v measured with DMM) if I try to run 1.275v at the same frequency to test and see if voltage control is the problem, it crashes driver as soon as I start 3D load.
What I've tried:
Drivers:
344.75, 350.12, 353.30, 353.38, 353.49
Classified tool versions:
2.0.5, 2.0.6, 2.1.0, 2.1.1
Tried windows 7, and windows 8.1 (fresh install of 8.1, it still did it)
Tried ClassyXX.rom, doesn't work, tried Joe dirt's bios, doesn't work, tried a bios from another user on this forum, didn't work.
Old 07-29-2015, 07:47 PM
Honestly man.. could just be the gpu not like voltage.. how are you on temps?
Have you replaced paste?
You on air or water?
Old 07-29-2015, 08:07 PM
Water, load temps 30-34c.
I think it is temps, is my only option to get it to scale to run chilled water or put my rad inside an ice bucket? ( can't afford ln2 since i just spent all my spare cash on my loop)
I can get my load temps down to 10-20c doing that.
Old 07-29-2015, 09:46 PM
Try redoing your paste on the gpu also.. could be a bad paste or mount.
Old 07-29-2015, 09:59 PM
My temps are ~7-9c over ambient, I don't think it's paste problem.
Do you think if I can get the GPU to 10-20c load temps it will help?
