  #31
Old 07-28-2015, 07:56 PM
Uing
Originally Posted by Pgcmoore View Post
http://www70.zippyshare.com/v/hpjnrFub/file.html
nvm, saw on other thread you found it.....
THX a lot
Old 07-28-2015, 09:43 PM
Forgot about voltage monitoring trick, in Precision X, added it.
Section "Enabling real voltage monitor".
Old 07-28-2015, 10:34 PM
But what about OC BIOS?
Old 07-28-2015, 11:02 PM
Checking, will be up soon.
Old 07-28-2015, 11:11 PM
cookiesowns cookiesowns is offline
Originally Posted by Menthol View Post
Let me know if you need one, I have a couple one with only 2 or 3 cables, don't remember without double checking
Awe. If gunslinger doesn't take it, would I be able to take it off of you?
As handy as a rasberry PI or USB-UART cable sounds, I much rather have a small tool that does the same thing.
Anywho. Thanks for the guide Tin! Managed to push 1562Mhz already, and pushing the vMEM up to 8300 on AIR! Going to try and hit the 1570 magic number on these cards that I have. Hopes are low, but let's be XOC on just air eh?
Also is there a way to adjust the following without EVBOT? I'm guessing not...
NVPWM, Sets PWM frequency for GPU VRM, from 750kHz to 1333kHz
FBVDD, Memory voltage, from 1500 to 2100mV. Best for LN2 around 1850-1900mV
PEXVDD, PCIe PLL voltage, from 1045mV to 1400mV
1VPVDD, GPU PLL voltage, from 1065mV to 1300mV
VIDVDD, Clock PLL voltage, from 1045mV to 1500mV
Massman's Avatar
Massman Massman is offline
Send a message via MSN to Massman
Just logged in for the first time in ages to say how epic this guide is.
THIS GUIDE IS EPIC!
Old 07-29-2015, 02:50 AM
AndreTM91's Avatar
AndreTM91 AndreTM91 is offline
Send a message via Skype™ to AndreTM91
This is great! Finally a sw that reads voltage correctly!
Today started great! I've just bought my 74%+ card!
i7-5960X@4.4Ghz; Rampage V Extreme; 16GB Ripjaws 4@3000 CL15; 980Ti K|NGP|N
Old 07-29-2015, 05:55 AM
Szeged Szeged is offline
is the link to the OC BIOS goobered up or am i out of the loop here
Old 07-29-2015, 07:55 AM
Saved the best for last. Ready for the XOC bios?
Get ready to Level up..
Old 07-29-2015, 08:01 AM
hallowen1's Avatar
hallowen1 hallowen1 is offline
#1 Outstanding Scores!, Congrats Vince!
bios, evga, gaming, gtx980ti, hardware tweaks, kingpin, kpe, ln2 overclocking, mods, xoc
