  #41
Old 02-03-2011, 03:34 AM
search specs of those chips by google,
they are not hard to find.
Old 02-03-2011, 11:42 AM
cold.nut's Avatar
cold.nut cold.nut is offline
Send a message via AIM to cold.nut Send a message via Skype™ to cold.nut
TiN will you review my work before I throw the mod on the chip. I'm doing a vCore mod to my M2N32-SLI Deluxe. Pushing to surpass knopfler .
I narrowed the core voltage controller down to ADP3186. Looks like pin 8 is the money maker here. I got an output of 1.504 on 2k setting with dmm. Thus 20*1.504 = 30.08k. So a 50k vr to ground should work the wonders right?
Double checking..
Old 02-03-2011, 02:27 PM
Seems your idea is correct, try that.
Old 02-04-2011, 09:51 AM
how about OVP for p8p67 deluxe :P
Old 02-21-2011, 03:44 PM
wesjuhdabomb wesjuhdabomb is offline
  • Mod request
  • Which hardware do you need to mod? VGA
  • Hardware model label? Geforce 8400 (G98)
  • What do you need? Vmem mod
  • What VRM controller does your hardware run? No idea.. have some pictures attached, also with vcore mod i found out my self, but there is no other pwm controller on the card...
  • Describe you issues, why you need that mod? More POWAH!
By the way, the capacitor on the picture above on the left side is 2.5v, so seems for mem.. but no pwm controller nearby?
Old 02-21-2011, 03:54 PM
Check you're layout of vga and all you're chips :
http://www.datasheetcatalog.org/data...onics/4817.pdf
Old 02-21-2011, 04:05 PM
But that one doesnt have a FB pin?
Old 02-21-2011, 04:11 PM
what i'm trying to say is that you look up you're chips on the pcb and look for info and datasheets of them, and like that you will find out what you need the alter the resistance to get more voltage on a item
Old 02-21-2011, 04:23 PM
Leave that logic 7408 alone, guys
Vmemory here regulated by linear power source.
on the first photo - SOT-23-3 "transistor-like" chip seems like TL432, it's driving power mosfet in DPAK package. Download datasheet for TL432, and recalculate resistor divider for wanted voltage (those 0603 resistors near GATE pin of DPAK fet). Take care not to make mistakes there
Old 02-21-2011, 05:03 PM
Thnx, will look into that tomorrow ! Ill show the results
