  #31
Old 01-01-2011, 03:55 PM
roelientjeL roelientjeL is offline
TiN, have you seen my request?
Old 01-01-2011, 04:44 PM
Yes
I asked to you somewhere
Use 7800GTX 256MB vmods. it's same PCB as for power.
You cant add 3 more phases by 'just connect', PCB designed only for present phases, no place to solder extra.
Old 01-01-2011, 04:48 PM
Quake's Avatar
Quake Quake is offline
Send a message via MSN to Quake
TiNs post
http://www.xtremesystems.org/forums/...4&postcount=97
VGPU
http://mitglied.multimania.de/seb484...0GTX_256MB.JPG
VMEM
http://mitglied.multimania.de/seb484...800GTX_256.JPG
Old 01-01-2011, 06:29 PM
don't be so hasty, he's a busy man, but will always answer.
Old 01-02-2011, 02:21 PM
Cyph3r_Smurf Cyph3r_Smurf is offline
Could you might help with CBB on a Graphiccard ? It can run nearly full pot LN2, but CBB is killing me.
Old 01-17-2011, 06:25 PM
BOBO's Avatar
BOBO BOBO is offline
Tin, quick request, would it be possible for you to look into a 570gtx and find out what mods need to be done to them? same as 580 ect... thx in advance... here's some pics lemme know if you mneed more...http://www.techpowerup.com/reviews/A...GTX_570/2.html
Old 01-18-2011, 05:48 AM
Yes, actually same.
Check out Shamino thread.
Old 01-18-2011, 08:23 AM
BOBO's Avatar
Thx for the quick reply Tin!
Old 02-01-2011, 07:21 AM
dejan_bin_laden's Avatar
dejan_bin_laden dejan_bin_laden is offline
Send a message via Skype™ to dejan_bin_laden
hello tin could you take a look at this i think non referent card its pcie HD3450 256mb from gigabyte
i took a picture of front because there is nothin on the rear, i tihnk i found vgpu but not the vmem i will apreciate if you take a peek
frist chip nexsem FB is pin 6 is it vgpu (it reads 3,08kohms) but other chips dont have FB pin ?!?!?! could it be the vcc one for memory...
thx for help iam noob for these things moded 3-4 to today ...
Old 02-03-2011, 03:32 AM
xoqolatl xoqolatl is offline
The 8-legged chip near the memory is BIOS. UM604L is a shunt regulator with 4 op-amps, but without a closer look at the PCB I wouldn't know how to mod that.
