  #101
Old 07-08-2011, 03:11 PM
d0minat0r d0minat0r is offline
like this?
Old 07-08-2011, 03:20 PM
G H Z's Avatar
G H Z G H Z is offline
sb cant touch this
Yes or you can drain off the non-GND side to another GND somewhere, your choice. Can't verify VR value W/O knowing the original resistance.
Old 07-09-2011, 07:58 PM
No
I have not seen your answer is wrong, but to what you proposed a solution
100K om is original resistance
Old 07-24-2011, 06:09 PM
Dolk Dolk is offline
For the PX3640 (8800GTX GPU voltage regulator) what Pin number am I soldering to?
Old 07-25-2011, 03:56 AM
Rsnubje's Avatar
Rsnubje Rsnubje is offline
think you mean PX3540
this is the mod
Old 07-25-2011, 10:52 AM
Mine is a 3640, but I believe its still the same layout. I need to directly connect to that pin, but I can't see where the tracers go :/
Old 07-26-2011, 02:21 PM
G H Z's Avatar
sb cant touch this
Work with your camera+macro/lighting a bit, if you have a decent camera you will be OK. Or if you suck @ that then just post a decent pic.
Old 08-28-2011, 04:13 AM
poparamiro's Avatar
poparamiro poparamiro is offline
VID mod request
TwinTech 9800GT 512mb
ISL6312 PWM
FB mod do not work, 3DM2006 @max1.27v possible (1.22v default load vGPU)
I attached pictures with PWM area on both sides, marked vid pins conections (vid5/vid6 are not connected)
Thanks
L.E.
Connecting the OVPSEL to VCC give me ~1.30v, after that shutdown occur again.
Old 08-29-2011, 06:08 AM
poparamiro's Avatar
I try to play with VID0-4 resistors on ISL side but no VID change, still 1.16v idle win - ~ 1.20v 3D load.
V0 resistor is 1k and V1-4 are 10kilo.
Old 08-29-2011, 06:23 AM
They are digital. So to make "zero" by VID table - you need to desolder resistor. To make "one" by table - you need to solder 1-10k resistor. Try that
