Old 01-31-2012, 09:09 PM
Bobnova Bobnova is offline
The heatsink on mine isn't lined up correctly
I'd like professional opinions: Should I RMA? Given that the warranty is DOA only, I'm inclined to.
Old 02-01-2012, 09:56 PM
Should be ok, you can realign, it just sits on sticky thermal pad.
I used EPOWER even w/o heatsink with fan on it for 580 memory, was working good for whole session.
Old 02-02-2012, 12:04 AM
Ok cool, thanks for the reassurance.
The sticky pad appears to be really sticky, I'll leave it as-is and give it a nice solid fan for good measure.
Old 02-02-2012, 05:56 AM
spl spl is offline
I HOPE to be available soon in Europe
Old 02-02-2012, 07:06 AM
You can try to get from http://www.performance-pcs.com/catal...ducts_id=33340
Old 02-02-2012, 12:06 PM
spl spl is offline
thanks
i try to order but can you help me here?
http://www.kingpincooling.com/forum/...?t=956&page=20
Old 02-02-2012, 03:07 PM
0skill's Avatar
0skill 0skill is offline
thanks for that tip just ordered 2 can't wait for release in EU
crappy 50USD for international express
Old 02-03-2012, 06:36 PM
Got it all wired up, in ohm testing the memory-gnd resistance was zero so I took it apart again.
There's zero ohms between memory voltage out and GND on the untouchables, even with the wires removed from the GPU.
Did I miss something obvious? Is it DOA?
The VCore side works wonderfully.
Old 02-03-2012, 10:36 PM
Did you power it up? Any solder shorts on output?
Old 02-04-2012, 04:05 PM
Found it, feel silly posting now :P
I scratched the solder resist while attaching the ground wires. It was a tiny little short, but a short it was.
A request for rev1.1: A bit more space between the GND pads and the VCC/VDD planes
Works great now, thanks!
