  #431
Old 07-15-2016, 08:46 AM
Mave74
Post GTX 970 HARD MOD
Mod Request
VGA
ZOTAC GTX 970 AMP! Extreme
What do I need? Voltage
Describe: I already got my Voltage mod and shunts shorted, but in short, when I am under load and I add Voltage (from 1.234 --> 1.29, sth.) my clock goes DOWN (from 1550->1530) otherwhise it would NOT be stable anymore. I've asked many people, couldnt find help :/
Thanks TiN!
Old 07-15-2016, 10:27 AM
DR4G00N's Avatar
DR4G00N DR4G00N is offline
That makes sense, I'll try it later today if I have time.
Old 07-17-2016, 04:10 AM
Mave74 Welcome,
Most of Maxwell GPUs not scale with voltage on air/water, it is known. You can read OC guides for 980KPE/980Ti KPE, where this was covered in detail. 970 is similar behavior.
Mave74 Welcome,
Old 07-17-2016, 05:06 AM
Oj0's Avatar
Oj0 Oj0 is offline
Originally Posted by Mave74 View Post
Mod Request
VGA
Thanks TiN!
You need more cold, not more voltage. At that frequency you're going to be wanting to keep your load temperature well below 60'c. More voltage isn't going to help you in the slightest, even if you go up to 1.350v or higher. You'll find you have less and less stability as your voltage increases unless you get that card colder.
REAL NAME JONATHAN
ROCKING, ER, CLOCKING IT OLD SKOOL
Old 07-17-2016, 11:40 AM
Mave74
Well understandable, but I have watercooling and it keeps the card at the mid 30's while furmarking, if thats a word :P
Old 07-17-2016, 11:42 AM
Mave74
Mave74 Welcome,
So there is no way around that if I am on watercooling hovering about 30's on full load? If there is no way, can I at least volt-mod the memory and get something out of that? Currently 2215MHz Mem on 1.6 Volt
Old 07-18-2016, 12:26 AM
Oj0's Avatar
Oj0 Oj0 is offline
Like I said, well below 60'c for the speeds you're getting. On a good card below 60'c I'd expect around 1,600 MHz max, on a typical sample around 1,550 MHz.
Your next step is going to be around 20'c under load, which should get you another 50 MHz or so. From here on the scaling is small and comes with massive temperature reductions.
REAL NAME JONATHAN
Old 07-18-2016, 11:09 AM
Mave74
So it's smarter to leave the voltage at 1.205 volt where the card hits 1560MHz? and maybe focus on the memory because I got that also watercooled
Old 07-18-2016, 08:08 PM
Yes, you are hovering with nice speeds there, I'd be happy to leave it as is. Even if you spend lots of effort and risk (e.g. chilled loop) to get magical 1600MHz, it would not be stable everywhere at max perf.
You can try memory at 1.7V-1.725V, perhaps you'll get hundred meg or so from that, for what it's worth
