  #421
Old 06-09-2016, 01:10 PM
Here example how it may look like. I used this as map for some power and repair work on FPGA board:
Old 07-09-2016, 01:40 PM
DR4G00N's Avatar
DR4G00N DR4G00N is offline
Hey TiN, do you know the VGPU & OCP mods for the Reference 7970?
PWM is the CHL8228G.
http://i.imgur.com/8pUKfUx.jpg
DR4G00N's Avatar
Double post.
Old 07-10-2016, 08:28 PM
Tried this: http://www.overclock.net/t/1374994/7970-voltmods
Old 07-11-2016, 10:36 AM
DR4G00N's Avatar
Yeah, I tried that first but it wouldn't work but I found out that I can just use an SMBus controller to change the voltage so that's what I'll do instead.
I'm trying to make a zombie out of it but I'm not having much luck.
The Enable and two VCC pins on the IC are connected to +3.3V power and the two +VSense pins are connected to the MLC output caps and the two -VSense pins are to GND. I'm only getting 300-400mV from the gpu phases though.
+12V side resistance starts @ 2.5K Ohm and rises and the output side sits at 96 Ohm and doesn't change.
Maybe I missed something or there's a short somewhere, any suggestions?
Old 07-13-2016, 08:11 PM
Perhaps post a photo of your zombie? Where it come from?
Is enable constant high (3.3V) ?
Make sure all power phases inputs get +12V, often some phases taking power from one +12V channel, others from other. This is common to split load per multiple +12V inputs evenly.
Old 07-14-2016, 10:27 AM
DR4G00N's Avatar
It's from an HD 7950 with a Reference 7970 PCB that has all Six gpu phases enabled.
http://i.imgur.com/4VZVdsZ.jpg
http://i.imgur.com/e2D8SKs.jpg
It's getting a constant +3.37V and all the phases are receiving +12V.
I'm going to remove all the black wires and try again, I'm pretty sure it's shorted because the output side is 96 Ohms to GND and while it was still attached to the rest of the card it was only about 6 Ohms. I'm going to try cleaning up the edge from where I cut it and hope that it was the problem.
Old 07-14-2016, 10:40 AM
Honestly I'd recommend not bother with ATI cards as zombies, and cut some NV card to do so. It's just easier and less finicky than most ATI power designs.
Old 07-14-2016, 04:07 PM
DR4G00N's Avatar
Yeah, I figured that would be the case once I started getting into it. I'll keep at it for a little bit longer though.
Old 07-14-2016, 06:03 PM
Try connect Vsense+ to output + and Vsense- to output- near same spot.
You need to have feedback loop closed for VRM to work. You reading 96 ohms because there is 100 ohm resistor to weakly tie sense+ to output. You need <10 ohms to ensure VRM controller is happy. So I'd try that, tie VSEN pin4 to output and see what happens.
