  #341
Old 04-05-2014, 04:12 AM
RULE RULE is offline
i'm trying to epower another old card, a good 4870 with adp3290 on the gpu vrm.
Here the datasheet: http://www.onsemi.com/pub_link/Collateral/ADP3290-D.PDF
There's the POWERGD on pin 2: Power−Good Output. Open−drain output that signals when the output voltage is outside of the proper operating range.
How can i understand if this pin must be cut before epower the card?
If i'm not wrong the open-drain output can be connected with a led. Is this the case?
Old 04-06-2014, 05:10 AM
Update:
I've quick soldered 2 wire for eliminate my doubt.
As i suspected a led turn on
After a quick test with aquamark i've see the card scale on 2d-3d clock mode, so i believe i can go ahead with soldering the epower.
Old 09-08-2014, 12:07 PM
overclock990 overclock990 is offline
Hi
Need Help for VID?
NCP5395T controller.
Old 09-09-2014, 04:33 AM
RRainbo's Avatar
RRainbo RRainbo is offline
Vid mods are simple
vid pin is usually routed to two resistors which only one is populated to determine logical value. Resistor values are not critical in this application they are usually around 10kOhm.
In datasheet you will find vidtable which define logic values on vids for different voltages.
Old 09-09-2014, 06:23 AM
All three resistors values are 10Kohm...Thank you.
Old 09-10-2014, 07:06 AM
You need have
VID7,VID6,VID1,VID2 connected to GND via 1-10k resistor, and no resistor to +3.3V
VID5,VID4,VID3,VID0 connected to +3.3V via 1-10k resistor, and no resistor to GND
to get "0x39" VID code you want.
Old 09-10-2014, 11:42 AM
thanks
where is voltage source?
Old 09-10-2014, 01:19 PM
RRainbo's Avatar
on pcie connector
you dont need to look for external sources you have everything routed on pcb you just add or remove resistors
Old 09-10-2014, 03:52 PM
thanks
Old 10-04-2014, 01:47 PM
game theory game theory is offline
hi tin and the other guys
old school comming when ucan't find Rex or the other legend u must work to hard
how ever
Mod request #lost count
motherbord
rampage formula or Ep45T-ud3r
OCP \OVP\vmod\vdroop\v nb mod and etc (any mod can help to get goal)
ASP0700(for RF) if i'mnot wrong
aiming pas 700 fsb white full ratio (e8400)
