  #51
Old 08-06-2014, 01:34 PM
hey guys can anyone confirm exactly what removing the resistor at the bottom of the first post does. Everyone says it's for gpu tweak but since it was posted after saying use hotwire for ov I'm thinking it's needed for hotwire. Also do we need to remove a pgr resistor for hotwire like we did on previous hotwire cards.
Ready to mod my card but just a little confused about everything that is needed. So far I know I have to short ln2 pads and setup hotwire but unsure what to do from there.
Would I be better off doing a vr mod using the hotwire point or is hotwire way to go.
Old 08-07-2014, 10:16 AM
It is my understanding that removing the resistor protects the memory while using GPUTweak. However it also prevents you from being able to use GPUTweak to raise the vmem voltage, meaning that you will need to use the hotwire mod to adjust vmem.
Old 08-07-2014, 12:05 PM
ok cool thanks. Sounds easy enough.
I'm guessing since bridging the ln2 pads unlocks gpu tweak that should be enough for hotwire also.
I'm still not sure if we have to remove a pgr resistor for a full hotwire mod like previous cards.
Bought my first soldering iron and been practicing on an old card. Hopefully I can get my card modded tonight. Really excited to test it out. They look like amazing cards.
Old 10-02-2014, 11:25 AM
nacho_arroyo nacho_arroyo is offline
One run on Heven with 2 R9 290X Matrix Platinum.
Hw used:
Asus Maximus VII Formula ROG
2x Asus R9 290X Matrix Platinum ROG @ LN2
SeaSonic 1200W Platinum
Corsair SSD Neutron
Corsair Dominator Platinum 2666MHz c10 @ 2800MHz c9
Intel Core i7 4790K @ LN2
Pics:
Resultado:
Heaven 2GPU (4to lugar mundial global 2GPU y 4to lugar mundial 290X 2GPU)
http://hwbot.org/submission/2640867_....91_dx11_marks
Great cards
Old 10-04-2014, 07:19 AM
mortisboy's Avatar
mortisboy mortisboy is offline
Great result mate...ROG power
Old 10-06-2014, 12:02 PM
Thanks Mortisboy !
Old 10-06-2014, 02:21 PM
one more run with 3GPU under WC, and CPU with LN2:
Old 10-17-2014, 05:02 AM
Start to test the OC Tool !
Thanks Asus.
Old 10-19-2014, 12:57 PM
Luumi Luumi is offline
Looking forward to see what you can do with the XCB. I still got one aswell lol, but no matrix cards since both my 780 ti ones said pop prematurely and flew to heavens.
Old 12-10-2014, 01:39 AM
coolice coolice is offline
Updated for matrix GTX980
3D BIOS 7400~9000
https://www.mediafire.com/?jbqwtjjctv19aq7
GPUTweak
https://www.mediafire.com/?a9o0ybdvtlxdtty
