Old 08-10-2010, 12:20 AM
HITandRUN's Avatar
HITandRUN HITandRUN is offline
Keep pushing it Tin! You are insane in a good way!
Old 09-13-2010, 05:58 AM
Cyph3r_Smurf Cyph3r_Smurf is offline
Have you worked more with the design ? I'm thinking on the microcontroller.
Old 09-13-2010, 06:02 AM
I will use ARM 32bit MCU from ATMEL (AT91SAM7S64 model).
Already have versatile modules done
Old 11-11-2010, 10:58 AM
Foamy's Avatar
Foamy Foamy is offline
You will need to run whole card in extra slot and desolder GPU from it, coz I don't have datasheet for UP6225 PWM to dig out some stuff. If you sure that it's exactly what you need - i will start dedi thread for lightning transformer guide
Is it possible to make something like that from the scratch? useable on every card?
Tin, did anyone already said you're a f***** genious? Serious dude i'm impressed by your knowledge and dedication
Old 11-11-2010, 11:01 AM
sure it is possible, design of DC-DC supply for GPU is not an alien technology from Mars, it's done by humans
But it's not worth spent costs for just one unit, too expensive (only bare PCB will go near 150-200$ min for size like untouchable). I have current vga maximizers projects onhold due this.
Old 11-11-2010, 11:07 AM
Foamy's Avatar
Uhu, was thinking the same.
And what about the possibility doing it the old fashion style?
Link to pic
soldering and wires!
Old 11-11-2010, 11:14 AM
with hundreds of watts of low-voltage power (>100AMP outputs) at near MHz frequencies.
You must be joking.
Old 11-11-2010, 11:16 AM
Foamy's Avatar
You must be joking.
epic fail i guess?
Old 11-12-2010, 08:23 AM
Quake's Avatar
Quake Quake is offline
Send a message via MSN to Quake
I know you were using several times voltage regulation from other cards... But what is ''the best'' card for that purpose?
Old 11-12-2010, 09:18 AM
EVGA Untouchable special module so far is the best
To speak seriously - there is no exactly "best" thing. It's DC-DC VRD schematics. Beffy cards want huge currents and large transients. So here fit best some multiphase beffy VRM with fast PWMs (like Volterra, uPI, CHIL's etc). Less beffy cards want less power, so some 4-6phase design with nice bunch of output caps fit here maybe better. It depends on where you want to go. Ofc in general - more beffy VRD will serve you more often.
