  #41
Old 08-09-2011, 04:24 AM
0skill's Avatar
0skill 0skill is offline
yes i know but we`ll just get the adresses when we readout the bus protocol
Old 08-09-2011, 05:23 AM
Now do you imagine readout of protocol with two devices on same address?
There is magic resistor for address selection on PWM
Old 08-10-2011, 05:28 AM
0skill's Avatar
Thx for the info
will try to find this magic resistor this weekend
Old 08-15-2011, 12:15 PM
0skill's Avatar
i can`t find magic resistor
just found some 0 ohm jumpers and some resistors but i`m not sure witch resistor is for adressing
does adressing works from 12Vinput to magic resistor and current flow over magic resistor to adresspin = adress?
Old 08-15-2011, 07:53 PM
from 3.3V
Try pin 20 300ohm is for stock addr, 1.02k for +1bit, and so on
Old 08-16-2011, 01:42 AM
0skill's Avatar
thx dude
you are the best
Old 08-19-2011, 12:17 PM
i think thats the smb going into the gpu, not linked with the rest of the devices on vga if not like tin said mobo + vga conflict may arise. better to solder to the controller smb
Old 08-19-2011, 04:28 PM
0skill's Avatar
no there isn`t a smb connection to mabo they don`t added jumpers
you can see it here on first pic http://kingpincooling.com/forum/show...6&postcount=33
now i`ve connectet the wires right to the controller to keep wires short won`t get bad signals
i removed the resistor and added a VR to find right resistance
right now i`m sitting here and try doing my homework
Old 08-21-2011, 06:17 PM
0skill's Avatar
need some help from the master
i`ve tried to get it working but no way
i`ve tried all possible resistance between 1,02k and 20,5k but no way
than i desoldert the adressing resistor from the 2nd 1165 controller (12,1k) on pcb and set resistance to 340ohm
retry 1,02k to 20,5K no way evbot would`nt work
but some strange things would happen with 6,49k and 12,1k @ R_sel0
3sec after startup VCC rais up to 1,66V
VGA is getting realy hot with stock cooler but still alife
Old 08-21-2011, 06:24 PM
you should better look for better cooling then that ugly stock cooler
2900xt, engineering madness, overclocking solder guys, zombie
