  #61
Old 05-02-2012, 09:11 AM
uhoh, in my coldmod you need not to short resistor, it's already 0 ohm if I remember right.
And if you have cold shutdown than it's not gray screen, it just shutdown -> black screen
red screen is voltage stuff, rest i dunno. I had no problems on my cards till -120...-150C, some go low -160's...-170's
Old 05-02-2012, 09:23 AM
slapmehard slapmehard is offline
The party was over for me @-42 just black screen,but unlike most cb its seems to still have power from card to monitor and 1.08v not 0v.
It pissed me off tbh.
Old 05-02-2012, 09:30 AM
BenchZowner's Avatar
BenchZowner BenchZowner is offline
Being a good boy :)
Originally Posted by Splave View Post
is there a special bios?
AFAIK no.
Coldslow was eradicated this time software-wise ( BIOS ).
TBH I'd not buy a 680 reference for LN2.
I'd wait for the custom extreme oc targeted cards ( Classified, Lightning, SOC, Zotac Extreme AMP! ).
To bench a reference properly on LN2 you need a proper external power source, you actually ruin the card warranty-wise, and it's still a "gamble".
*.*Puts money aside*.*
Old 05-02-2012, 09:44 AM
easy enough, I will remove resistor instead and perform OCP mod and test in a second.
Old 05-02-2012, 10:30 AM
okay removed resistor instead of short and performed ocp
will try after client meeting in 1.5hours
Old 05-02-2012, 11:51 AM
Look like a mess
GL, hope it will be ok.
I had lil different approach, but i guess should be no much difference.
Old 05-02-2012, 12:14 PM
Look like a mess
gotta clock awesome then right?
EDIT: Well seems to be able to handle colder temps -75c idle freaks out at -112c in bench. But its not scaling anymore with temps needs more stable voltage and getting red screen if I increase voltage passed 1.63v. Guess this is where epower comes into play?
Old 05-02-2012, 02:42 PM
I think your doing real good splave
but next time around might be in the ground. :
1.6v stock board
Old 05-02-2012, 03:43 PM
michael_rw's Avatar
michael_rw michael_rw is offline
Default Is this right?
I cant find a 7 position DIP switch, so will be using an 8-position switch instead.
So this is what I'm seeing in the pictures:
Does this look correct?
Thanks for the help
EDIT: Im only trying to raise the voltage more than the allowed 1.175V. I am only using a full cover copper water block, so was thinking maybe around 1.3V would be good.
Old 05-02-2012, 04:11 PM
1.6v stock board
lol! I know i was thinking the same but its running like a champ at 1.62, maybe my meter is broken
