  #71
Old 04-29-2014, 07:58 PM
bob(nz) bob(nz) is offline
Just having my first play with the two cards I picked up, Loving the design, performance on air is just amazing (boosting 1350 at stock volts). Great work Vinbo and Tin!!!
First tests on LN2 have been a bit challenging, was having all sorts of issues to start, so went back to basics and just focused on core clock to start with. Easy 1750 at less than 1.45v on both cards, one losing display at -75 and the other at -95. Will have round 2 with more volts soon!
Definitely some challenge with the memory, best card running at 2000+ on air! but any additional volts causes pixelation on ln2, if volts left untouched +120 possible, but anything further crashes. Once I max out the cores I will start to try some different settings for memory under cold (thinking maybe pwm freq could help?)
Old 04-30-2014, 02:44 AM
Doug2507 Doug2507 is offline
IIRC when StrongIsland went cold on them 1st time out he had the same sort of issues with mem then re-insulated going heavy on the mem and alleviated some of the problems….
Old 04-30-2014, 04:42 AM
Okay thx, will also try this to see if it makes a difference. Just using Vaseline at the moment with a paper towel gasket....
Old 05-06-2014, 05:04 AM
Billy-The-Kid's Avatar
Billy-The-Kid Billy-The-Kid is offline
Send a message via MSN to Billy-The-Kid
bob... any new´s about using only vaseline?
Old 05-06-2014, 09:39 AM
Everything mounted up and ready to go, but haven't had the time. Hopefully by the weekend......
I have made a foam gasket to try and isolate the core a bit, will see if it makes a difference
Old 05-07-2014, 03:41 AM
I already teste and test again .. i try with air drier and the same in my case
Old 05-20-2014, 11:39 AM
motek-18 motek-18 is offline
Hello
I have a GTX 780 Ti Classified K | NGP | N Edition & EVbot
but no X58/79 mobo, just a Z87 Classified mobo.
how can i evbot new firmware for EVbot
Old 05-21-2014, 03:50 AM
Get update tool from here. Plug EVBOT into your VGA, and then run follow instructions.
Old 05-21-2014, 02:26 PM
ok
but what is that:
NVVDD ----Vcore GPU
NVPWM
FBUDD
FBOCP
PEXVDD
PEXPWM
Old 05-22-2014, 05:23 AM
RRainbo's Avatar
RRainbo RRainbo is offline
NVVDD ----Vcore GPU
NVPWM -Vcore gpu switching frequency
FBVDD -mem voltage
FBOCP -mem overcurrent protection
PEXVDD -pll voltage
PEXPWM-pll switching frequency
